2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-05T18:39:07+00:00
    Agreed on both counts.  These are the primary reason I ended up with a SB2.  Given the price and that both the hardware and OS are from Microsoft, I expected top-notch integration and support.  Like you, I haven't seen it.
    I was hoping that an MS laptop would have tigher Windows integration..... sadly it doesn't. My X1 Thinkpad has had some other annoyances, but driver issues are not one of them.
    I won't make the comparison to apple as they have their own issues, but they do tend to fix things when enough users scream. For the price of the SB2, I would think MS would be more responsive, and offer an Apple like level of customer support. I haven't seen it.
    2018-10-11T02:27:04+00:00
    OK, I have to edit my reply about my dGPU not being recognized.  Turns out I purchased the SB2 13 inch i5 model which does not include the dGPU.  I apologize for any confusion caused.  I do think this discussion is still relevant for other users that have dealt with the issue at hand.
    2018-10-11T02:44:50+00:00
    I've tried everything. I ended up getting a full refund (in store credit) from where I bought it at JB HIFI. It's too bad because, without that flaw, it was actually a pretty promising innovative machine. Oh well.
