2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-05T16:18:54+00:00
    As far as anyone can tell it's not a hardware fault. The thread has been pretty quiet since MS released the driver and system updates in August.
    However, I did end up doing a hard reset (wipe everything) since my SB2 exhibited some minor oddities after those updates. It seems to be ok since the reset.
    The problem is that since the problem only occurs every few months (assuming you do the hard restart (not reset) as mentioned in several of the entries, then it's difficult to know if these drivers have fixed the problem or the problem will come back in a few months.
    For me, the hard restart (which only takes a couple of minutes) every few months is no big deal. The sad truth is that all laptops exhibit issues, I've known people with HPs, Apples, Lenovos, all with strange things that never really get sorted.
    Not sure why MS have pulled the driver pack though, that's odd. I wonder if it will be incorporated in the October Update.
    2018-10-05T17:08:06+00:00
    Guess they either caused another issue with the 13" or don't think it's an issue for us.
    Glad I only spend a few grand on the top line 13" to not get any driver updates in 6 months when the 15" seems to have had patches for flaws in bios, amongst other things.
    How reassuring.
    2018-10-05T17:29:47+00:00
    How reassuring.
    I was told they pulled it due to issues with bitlocker. A shame that 30 drivers were pulled when likely only one is to blame. And of course no communication with customers.
    I was hoping that an MS laptop would have tigher Windows integration..... sadly it doesn't. My X1 Thinkpad has had some other annoyances, but driver issues are not one of them.
    I won't make the comparison to apple as they have their own issues, but they do tend to fix things when enough users scream. For the price of the SB2, I would think MS would be more responsive, and offer an Apple like level of customer support. I haven't seen it.
    I do know that the problem is not hardware, but if enough users kept taking in the base when the GPU disappeared, MS would have to do more then they are doing.
