2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-09-21T12:41:14+00:00
    Thanks for the reply mate, I've taken it back to jb hifi and gotten a full refund for store credit. Unfortunate because I really did enjoy the sb2 and all the designer friendly aspects about it. Probably gonna go for a Razer blade 15 as replacement .
    2018-09-21T12:55:36+00:00
    Looks good!  Its such a shame as for designers it wokld be fab - if it worked! Got my Lenovo P1 on order and have always found them reliable as a company and as a product.
    2018-10-05T15:55:09+00:00
    Update 8/1/2018:
    Hi Greg(MSFT)
    This thread has been on going for a long time. Any fix yet? Microsoft pulled the August SB2 driver pack, so our latest drivers are from May.
    I have an extended warranty but not past year one yet. Should i replace the base every time this happens? Will Microsoft fix the problem if we all just go to the MS Store and get a new base every few months?
