2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-09-21T01:32:06+00:00
    I have the same issue.. GTX 1060 no longer detected. Attempting to get a replacement laptop without having to send my laptop to Microsoft for 3 weeks just to tell me what I already know.. **** seems to be making things alot more complicated. Next time I might have to buy from the Microsoft store, if there even is one around where I live..
    2018-09-21T08:18:07+00:00
    Don't bother with a replacement, they all suffer from it, it seems to be a software or firmware issue.
    Have you tried the hard restart mentioned as the second answer at the beginning of this thread?
    It will solve the problem for at least a few months (at which point, if it happens again, you just do the hard restart again).
    Note, it's just a hard restart, not a reset, so it's not wiping anything and only takes a couple of minutes.
    2018-09-21T08:39:19+00:00
    Well although have had total stress, lost wasted hours on fixing, research, 50 emails, forum and phone calls after escalation have finally got my money back and wont touch microsoft hardware ever again.  Product was shocking that it was ever on the market without ful testing  and the customer  service even worse
