2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-09-01T01:16:49+00:00
    In a recent update I have noticed you are no longer supporting a polling rate of 1000hz and only 500hz.  Was this change made to stabilize the GPU?  Because this is very frustrating.  I can not get my G903 mouse now to stop stuttering on 1000hz when it used to work just fine.  It took me a serious amount of frustration and determination to figure this out was the issue.  Please confirm that 1000hz is still supported or not in the most current update to Windows 10 for the Surface Book 2.  Many digital media and CAD creators need the support for 1000hz back if you removed it please!
    2018-09-04T00:35:58+00:00
    I have the Surface Book 2 15" 512GB i7 and the NVidia GPU is only detected after a detachment and reattachment.
    A cold or simple restart/reboot loses the detection of the NVidia GPU and this is simply annoying having to do a detachment and reattachment.
    Surely, this is not acceptable.
    I only use the Surface Docking Station both at work and home, so power is not an issue.
    I have all the latest drivers and this is such a fundamental point of having the upper end of the Surface Book 2.
    I appreciate the moderators trying to help but their answers here are useless, and more to the point very unhelpful!.
    So, Microsoft! What is up with the Surface Book 2? You selling duds?
    2018-09-11T19:00:56+00:00
    hello,
    I already have the lastest update installed and still have issues with the display driver. See summary of report below:
    On Tue 9/11/2018 2:27:42 PM your computer crashed or a problem was reported
    crash dump file: C:\WINDOWS\MEMORY.DMP
    This was probably caused by the following module: nvlddmkm.sys (0xFFFFF803C8EB466C)
    Bugcheck code: 0x116 (0xFFFF9980E5DA8010, 0xFFFFF803C8EB466C, 0xFFFFFFFFC000009A, 0x4)
    Error: VIDEO_TDR_ERROR
    file path: C:\WINDOWS\System32\DriverStore\FileRepository\nvmso.inf_amd64_8461c3207f0421af\nvlddmkm.sys
    product: NVIDIA Windows Kernel Mode Driver, Version 391.40
    company: NVIDIA Corporation
    description: NVIDIA Windows Kernel Mode Driver, Version 391.40
    Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
    A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 391.40 , NVIDIA Corporation).
