2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-22T13:49:58+00:00
    I rolled back the 2018-02 Cumulative update and it is working again.
    2018-02-22T13:50:12+00:00
    I am in this exact same boat and have tried all of the recommended fixes across forums, etc.  Is this something we should sit tight on and wait for a patch to fix as everything was working fine until the recent patch that broke it?  Was really loving this machine until this recent issue.
    2018-02-22T14:03:31+00:00
    As mentioned above, uninstalling the 2018 02 CU seems to have fixed it for me. I have now paused updates and will wait to see if the next one addresses this before deciding to go to a different machine.
