2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-21T17:37:11+00:00
    What type of connection do you use at the monitor?
    If you use a DVI connection at the monitor, you might check to see if you have passive or active cables. My understanding is the Surface Dock doesn't support dual-mode display (DP++) and so it doesn't properly convert the signal from mini display port to DVI, but active cables have a chip that does the conversion even if the dock can't. There's a better explanation here https://surfacetip.com/best-active-mini-displayport-dvi-adapter/
    Hope that helps
    Thank you for the suggestion.  I'm using DisplayPort input on the monitor, so no DVI converter being applied.  I have to think this is software-related since it worked about 80% of the time before the latest firmware, and now works 0% of the time.
    2018-08-23T17:22:38+00:00
    I deeply appreciated this solution, with an almost brand new Surface Book 2, and being miles away from shore, this really helped, I was deeply concerned that I had purchased a lemon, thankfully this worked.
    2018-08-23T21:31:01+00:00
    Well i hate to say it but i took my SurfaceBook 2  back today and traded it in for a Surface Laptop, after all the tips and tricks and BS you have to do to get things working and 3 laptops later all with the same issue and Microsoft not publicly addressing or fixing this i'm done with the SurfaceBook line of laptops.  Paying almost $4000.00 and having to do all this crap that everyone lists is not ok, it's actually ridiculous.
