2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-21T11:16:59+00:00
    My only current issue is that my external monitors (two connected through Surface Dock) never wake after the laptop goes to sleep now.  Used to be a problem from time to time with one of two monitors, but now it's every single time.  Very annoying.  Yes, latest Dock firmware applied, too.  Windows "thinks" they're there, but the monitors get no signal until I undock, wait for everything to adjust, then re-dock.
    2018-08-21T13:11:21+00:00
    What type of connection do you use at the monitor?
    If you use a DVI connection at the monitor, you might check to see if you have passive or active cables. My understanding is the Surface Dock doesn't support dual-mode display (DP++) and so it doesn't properly convert the signal from mini display port to DVI, but active cables have a chip that does the conversion even if the dock can't. There's a better explanation here https://surfacetip.com/best-active-mini-displayport-dvi-adapter/
    Hope that helps
    2018-08-21T16:31:32+00:00
    Hope that helps
    Nah,
    I'm using a straight  usb-c to Display port  straight from the SB2, I have not invested yet in the dock.
    I have to set all my power settings via the battery slider to the lowest possible setting or else my temps on my cpu hit over 200 degrees F.  just having Edge or chrome open watching Netflix (with or without the second monitor) my temps and usage are at 60-100% on the CPU and integrated GPU which pushes the temps to over 90+ degree Celsius..
    I have figured out that setting gpu settings in both nvidia and the windows control = a bad idea.  And to use one or the other.
