2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-09T13:50:33+00:00
    Yeah, I'm pretty sure it isn't my monitor which is a 6 month old Spectre. Haven't had any trouble with it on other machines, or, with this machine in the past before the update. Also, the freezing requiring a hard reboot is clearly something about the dock-SB interaction.
    2018-08-09T14:05:52+00:00
    I didn't state my comment very well. I don't think there is anything wrong with your monitor per se.
    Instead, I'm suggesting that the Surface Dock may be a picky eater. It may interact with a different monitor better or worse than the one you are currently using. I've found that different brands of monitors wake/refresh/sleep/etc. differently.
    Trying a different monitor might not be feasible, but if you can and it works better for you then at least you can point to an incompatibility issue that needs to be investigated.
    2018-08-09T14:23:45+00:00
    Was it set to 8bit before the update? And it changed after the update?
    Please reply if the rollback driver solved the issue.
    Yes, it was set to 8bit before and changed to 6bit after the update.
    The only thing I did was update the Surface Dock firmware but this didn't solve the problem.
    I didn't actually get to try a rollback of the driver but a couple of days later it reverted to 8bit for no apparent reason.
