2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-09T13:36:16+00:00
    Update: It didn't solve the problem. I updated the firmware on the dock successfully following the directions here. All the Surface software and drivers are current using MS's Aug 1 update. Twice yesterday, the surface lost my external monitor and froze, requiring a hard reboot.
    Glitches I can live with. Twice a day crashes requiring a hard reboot I cannot.
    2018-08-09T13:41:50+00:00
    What brand of monitor are you using? I run a couple of ViewSonic VG2239m's and they've been pretty solid after the updates. If you have access to another brand/model of monitor it may be worth giving a shot to see if the problem still persists or not.
    2018-08-09T13:46:07+00:00
    I've also had monitor issues after the last firmware updates for the Surface Book 2 (15" Core i7).  Using a Surface Dock and two external monitors, I would have an issue maybe once a week where one or both (not consistent) of my external monitors would not wake up in the morning when I woke up my laptop.  The laptop screen would power on and Windows was clearly still using my 3-monitor layout configuration with the assumptions the monitors were on.  I would see the power light change on my monitors like they were supposed to be waking up, but they would then display "no signal" and shut back down.  Honestly, I thought it was a monitor issue.
    Ever since the August Firmware Updates, this issue now happens every single time I wake up my machine and always impacts both monitors.  The only way I can get my monitors to display content is to...
    Option 1: Disconnect the dock, wait for Windows to return to single monitor mode, then reconnect the dock.  If I disconnect and connect before Windows adjusts the layout, it doesn't work.
    Option 2: Fully power off each monitor.  Wait for Windows to disconnect the monitor and resize content, then power back on the monitor.
    Both of these options result in my application windows being moved around and/or resized.  My Surface Dock firmware is also up-to-date.  While I used to think my monitors had problems, this is clearly being driven by the laptop and/or dock.
