2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-07T22:14:45+00:00
    I use the Surface Dock and have experienced similar strange monitor issues plus ethernet issues. The dock seems to have software/firmware that runs inside of it.  ...
    I had tons of strange screen flickering issues with the Dock until I ran the Surface Dock Updater process:
    https://docs.microsoft.com/en-us/surface/surface-dock-updater
    2018-08-07T22:38:40+00:00
    Thanks for sharing that link Jonathan. I wasn’t aware there was an update tool available from Microsoft for the Surface Dock.
    I’ll definitely be checking my firmware version!
    2018-08-08T00:03:11+00:00
    I just ran the surface dock updater and had problems.  As part of the  process you have to disconnect the surface dock from my surface book 2.  When I was prompted, my external monitors were of course disconnected as well (I should have done the process with just the SB2 screen), after which I got no more prompts as I should have regarding the installation.
    So I restarted (external monitors off) and reran the surface dock updater with the option to "repair" the installation.  This worked ok, but required a restart, after which my SB2 screen was upside down.
    Played around awhile, and what fixed it was to detach and re-attach.
    Maybe the lesson is to first disconnect all monitors attached to the surface dock before attempting this update.
