2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-07T20:37:33+00:00
    One step forward. Two steps back. That's soooo Microsoft.
    So far, my NVIDIA card seems to of stopped dropping off, but, with that benefit comes an odd curse. My connected monitor (using the surface dock) flickers in and out every couple minutes and occasionally drops out entirely. Jiggle and replacing wares doesn't help. Replacing the dock connecter doesn't help. When the screen drops completely, the whole system becomes unresponsive and the only thing I can do is a hard reboot using the power button. It has happened 3 times since I upgraded yesterday. Jesus Christ Microsoft!
    Why did I buy this computer? The promise of both tablet and powerful laptop is totally undermined by ineffective software when used as a tablet and the GPU not functioning properly as a laptop. So basically I have a very expensive low end laptop.
    2018-08-07T20:40:47+00:00
    +1 Why can't you vote up a comment in here?
    2018-08-07T20:53:28+00:00
    I use the Surface Dock and have experienced similar strange monitor issues plus ethernet issues. The dock seems to have software/firmware that runs inside of it. So you might try rebooting it:
         1. Unplug power to the dock for a few seconds (recommend at least 30 secs)
         2. Leave everything else connected to dock including your Surface Book (seems to help drain any residual power in the dock)
         3. Plug power back into dock and allow all connections to come back.
    This doesn't seem to help with all of the monitor issues, but it does help them maintain a more stable connection if I do this every now and then. It definitely solved my issue of not having an ethernet connection. I was being forced to use wi-fi only, but rebooting the dock brought ethernet port back up...Maybe you've tried this already, but if not hope it helps.
