2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-06T19:29:48+00:00
    Update 8/1/2018:
    After the 8/1/2018 update Windows Hello stopped working on my Surface Book 2.   On power up the camera could not be found by Windows Hello.
    To resolve I had to change two things:
    1) Control Panel/Power/Choose what happens with power button/DISABLE the option "Turn on fast startup.".
    2) Run/gpedit.mac (Local Policy Editor).  Go to Admin templates, Windows Components/Biometrics.   Enable "Allow the use of biometrics" and "Allow users to log on using biometrics".
    After the May 1 update the NVIDIA 1060 card was no longer available and I had to use the method described by many of unplugging the power, starting the laptop using the power button and + volume control, then choose restart.  That woke up the NVIDIA card.  Between March 2018 (when I purchased to SB2) and May 1 the NVIDIA card was present.
    Before the 8/1/2018 update, ArcGIS Pro utilized the NVIDIA 1060 card nearly 100% as displayed in Task Manger.  After the 8/1/2018 update it appeared to be a nearly 50/50 share between NVIDIA 1060 and Intel 620.
    UPDATE: For the "TODAY" discussion below I realized that I was fooling myself.  I was running on just the battery while testing.  And so the NVIDIA card was offline because of that.  Once I connect to power the NVIDIA came back online.  Use distribution is about 50/50 Intel/NVIDIA while running ArcGIS Pro.  Before connecting the power I ran the NVIDIA driver update from device manager and Windows did update the NVIDIA driver even though I had installed the 8/1/2018 Windows update.  So not sure if the NVIDIA driver update is included in the 8/1/2018 Windows update.  After the NVIDIA update, in the Control Panel/NVIDIA Control Panel the ArcGIS Pro item is no longer present.
    TODAY:
    It looks like I made the mistake of using the Control Panel/NVIDIA Control Panel application and adding ArcGIS Pro to the list of items.  When I added ArcGIS Pro the graphics option was set to "auto NVIDIA" which I selected.  NOW, the NVIDIA card is not being used at all by ArcGIS Pro when I view activity in Task Manager.  And it appears there is no way to remove ArcGIS Pro from the list.
    I've tried removing the NVIDIA driver and letting Windows reinstall it.  No joy.  Task manager/Performance tab displays the NVIDIA driver but it has zero activity and memory use.
    2018-08-07T09:00:30+00:00
    Update 8/1/2018:
    After this update, my external monitor is now set to a Bit Depth of 6-bit rather than 8-bit which results in severe colour banding.
    I can't find a way to change it, will try to rollback the update later today.
    I'd rather have to go through a forced restart every few months then have a terrible looking image on my monitor.
    2018-08-07T14:06:27+00:00
    What frustrates me the most is for 8 months plus they have denied the problem existed.  Then all of sudden once I threaten to get a law firm involved, plus the next thing you know there is an article referencing my note about engaging a class action law suit.  Now all of a sudden there is an update released to fix a non existant problem?  Microsoft get your story straight!  Was there a driver problem or not?  Is this a fix to a real documented issue or is it a fix to a ghost issue that you will not offically acknowledge?  Just looking for clarity because your story has changed so many times!  Your a buch of quacks.  Its ok when your system took a **** on me during the intial setup after hours of tech support it was never fixed and my office program was still broken.  So I did a full complete restore and lost lots of data because backing up the data kept failing.  Your products are crap and your support is the worst in the industry.  I think your trying to establish the standard for the worst support ever.  Never Microsoft again.  At least I can get a straight answer from Apple.
