2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-04T22:03:35+00:00
    I left it unplugged until the system completely rebooted because the graphics card should get enough power through the battery.
    I never had the problem again that the Nvidia GPU disappears....but I had the detaching problem as well which was completely my fault.
    Because I use the Nvidia drivers and update through the Geforce Experience software I also have the Nvidia Control Panel and once I changed the settings that the system is forced to use the gtx 1060 which causes the problem that when I run a program which uses the gtx1060, the detach process has the failure, so I changed back that Windows is controlling which GPU is used and since then everything works fine...
    2018-08-04T22:36:52+00:00
    ....so I changed back that Windows is controlling which GPU is used and since then everything works fine...
    Isn't this one of the fundamental issues here?
    Windows doesn't actually do _anything_ to control "which GPU is used".  Windows itself just ignores the fact that you paid extra for a high-power dGPU and uses the woefully under-powered GPU that comes on your "primary" video card.
    Sadly, the best implementation for handling GPUs comes on macOS which makes switching GPUs a first-class experience and an OS-level concern.  Not only does it make switching GPUs trivial for even non-technical people, it provides "automatic graphics switching" to/from dGPU based on your preferences: https://youtube.com/watch?v=KtpZF22H9no&feature=youtu.be&t=44
    Just like with Apple and their MacBook, Microsoft controls both the hardware _and_ the OS with their Surface Book.  Given that, there's simply no excuse for falling behind on a semi-basic feature that Apple made available to its users over 5 years ago.  :/
    If Windows did provide both auto-switching and user-friendly GPU switching, we likely wouldn't see the issue we are seeing.  While no one really knows what the problem is exactly, it's clear that there is not a well-defined standard for handling GPU concerns on Windows, and we are stuck trying to figure out who to blame or simply how to hold them accountable.
    2018-08-05T07:04:38+00:00
    Am I completely mistaken or does Windows 10 1803 build 17134 provide means to set which GPU should be used?
    In "settings display graphics" there is a feature that allows me to choose which GPU to use, for UWP (Windows Store Apps) as well as for any Classic Apps (any .exe file) .
    The Nvidia App is officially not available anymore but can still be activated from the Nvidia folder. This App lets you set the GPU for any . exe file and also provides GPU choice on the right click menu of an exe file or on it's shortcut.
    It does not let you set the GPU for UWP Apps.
    Earlier Windows 10 builds did not let you set the GPU other than with the Nvidia Apps. UWP Apps were supposed to automatically switch to the best suited GPU, possibly driven by a switch coded into the respective Apps, i. e. "If dGPU available then use dGPU else use standard GPU."
    The new feature works perfectly on my SB 2 15" since the new build, the old builds were somewhat haphazard, possibly due to missing switches in UWP apps.
