2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-08-03T17:31:46+00:00
    Considering how long the problem has been around, Microsoft does seem to adding insult to injury.
    What surpruses me, is that MS does not acknowledge any problem in the matter. Neither the technical problem nor the - in my eyes far greater one - of reputation.
    Customer problems should always - always - be taken seriously. If one does not, one runs the risk of not having customer problems for lack of customers.
    2018-08-03T22:32:28+00:00
    Thank you Philip,
    One question - do you reattach the power to the base unit before rebooting, or after?
    I assumed that it would be best to reattach the power cable while it is off, so that when it restarts it will have full power available to power the graphics card.
    Thank you for posting this. It worked for me once before, some time ago.
    I'll also throw this in for what it is worth.
    I've been through this a couple of times, including getting a refurbished unit sent to me before I found this solution.
    My recent success story included a strange factoid.
    At some point, my Surface Book 2 assumed I wanted to detach the monitor and was complaining that I needed to turn off Steam in order to do that. I could NOT get the message to go away, nor could I detach my monitor. But, during that entire time, I never lost my Nvidia GPU.
    Today I noticed something wrong and sure enough, the Microsoft Surface Book 2 had lost the Nvidia GPU. And all of the warnings about detaching the monitor were gone too. So there appeared to be some correlation between the machine THINKING that it could not detach the monitor because something was running that needed to be turned off first.
    I only offer this to try and help anyone who is trying to figure this out (not Microsoft apparently) with as many details and facts as possible.  I'm off now to see if your trick worked or not, or if I have a crippled laptop again.
    I am so disappointed in Microsoft and the way they are handling this...
    -TS
    2018-08-03T23:50:18+00:00
    You should unplug the power cord after doing a shutdown and before doing the "hard restart":
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard restart by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    4. Plug-in the power cord when desired.
