2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-26T21:17:33+00:00
    Looks like I'm about to be on my 5th unit.  Today the fan started failing on #4.  I've only had it about 10 days.  Under moderate load (just app development and debugging), it started making a loud noise like a weed whacker!  Came and went for a couple of hours while I was working.  These things never get better with time and the unit may not even be cooling properly now, so I'm heading to the local MS store today to try to get a replacement in person... for one new in a box, and not something clearly refurbished.
    At some point I will surely land on a unit that works, right?... right? :'(
    2018-07-26T21:19:45+00:00
    Interesting article link:
    https://www.computerworld.com/article/3292576/microsoft-windows/yet-another-surface-book-2-problem-gpu-not-detected-microsoft-doesn-t-care.html
    I had the same problem,  but the fix mentioned in this forum has worked for me.
    2018-07-26T21:22:36+00:00
    First the power button issue, now this.
    This was my last microsoft laptop, to say the least. I'm never had so many issues with a laptop. I've owned 6 or 7 and never remember having issues like these.
