2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-25T16:02:40+00:00
    I also had the issue of "detach hardware failure" after the May OS update.  Forgot to mention that.  That problem eventually stopped I think by the end of May.  Possibly because of an additional OS update.
    2018-07-25T16:30:53+00:00
    "Are they waiting for the 1 year guarantee to be over?"
    In the EU and Switzerland the guarantee period is 2 years. So steel yourself for a long long wait . ..
    2018-07-25T16:35:52+00:00
    In the meantime the machine is sitting collecting dust in my son's room and is not able to be used for Industrial design at University......
    Apart from Microsoft's mysterious Greg who has still not replied to any of these messages .....tecchnical support are emailing me telling me  "it is not a recognized flaw "!!
