2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-25T15:23:36+00:00
    If the procedure described by Podsnafu does not work add step 1a, disconnect the power supply.  Then do the remaining steps while being powered with the battery.  In Step 5, click the option to Restart.
    2018-07-25T15:38:31+00:00
    For me the issue appeared after an automated OS update that occurred in early May 2018.   I recall noticing after that update that the NVIDIA card was no longer being displayed in the Performance page of Task Manager.  I wasn't all that concerned about it until July when I opened ArcGIS Pro and experienced significant reduction of graphics performance compared to what I had observed with this app before the May update.  So I'm not convinced the Surface Book 2 was shipped with the problem.   Appears to be a problem caused by the May 2018 automated OS update.  But I agree that it is frustrating that Microsoft and NVIDIA have apparently not acknowledged the problem.  They are probably still in that phase of blaming each other.
    2018-07-25T15:52:48+00:00
    I had the same problem with the same model. First the "detach hardware failure" sign started appearing on the bottom of my screen and after some days the device wouldn't turn on unless I detached it from the base. After a few more days it wouldn't detach and turning it on was a matter of luck.
    I went to a MS store and, after spending 2 hours of my time with one of the techs trying to fix it (trying hard restart, reset, updating/reinstalling NVIDIA drivers) they decided to replace it. The problem is that they have "special units" for replacement, which aren't completely new (they are refurbished units, but they don't really tell you that unless you ask!). So now I have a refurbished item in place of a brand new computer which will probably run into the same problem within a few weeks/months. And that's not to mention all work time lost trying to fix this issue.
    This problem has been known for some months now and we still don't have a clear answer from Microsoft. Nothing effective has been done to address this situation.
    As harmed consumers we should start considering class action litigation as we are clearly facing the case of a defective product. Microsoft agent's response was on March 19 and since then there has been no new update. Really? Am I missing the updated response? What has Microsoft been doing for the past 4 months? Are they waiting for the 1 year guarantee to be over?
