2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-23T17:22:39+00:00
    I have submitted the info to this issue to a law firm that handles consumer protection cases to review.  If your also interested in contacting the same law firm.  Please do so at this link:
    Krohn and Moss Consumer Law Center
    https://www.yourlemonlawrights.com/
    I look forward to seeing if getting a firm engaged will spark Microsoft to fix the issue quickly or end up loosing big time right in the public eye.
    Microsoft its time to step up and fix this issue or I can only assume that making law firms aware of this issue that specialize in specific cases like this will not end well for you.  Are you ready to fix it now?
    In the UK this is my latest reply from Microsoft
    "I did do a Google search and checked the sites that you mentioned on the first email it was cited.  Regardless of what we took from the search, it is not a recognized flaw and past the first 30 days, I cannot process a refund.  Beyond that the standard support options are available as previously discussed."
    I cannot understand when there are many of us experiencing this,  Greg the moderator has said to watch this space we are working on this fix yet the Customer Support Services are denying there is a problem
    • make up your minds Microsoft!  Its very very poor!
    Microsoft want to close my help ticket as don't see there is a problem?!!  Seriously is this an unmoderated forum ?  How can they ignore so many people and when you Google the issue its on so many other forums too!  This product should never have been released as not properly tested
    2018-07-23T18:54:56+00:00
    This works.
    Well it did for me so far.
    2018-07-24T04:09:12+00:00
    My issue is not resolved by any of these answers.
