2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-19T23:54:10+00:00
    Hi Noah,
    Thank you for the information you have provided. We're currently investigating a possible root cause and solution for this issue. We suggest that you continue to check for updates for your Surface and Windows to ensure your device has the most current firmware and software available.
    In the meantime, you can run the Surface Diagnostic Toolkit. It runs a series of tests to diagnose your Surface device. The diagnosis and repair takes about 15 minutes as it would check for both Windows and driver updates. It will automatically install any missing Windows update or driver and firmware update for your device. Click **here**to learn how to run the toolkit.
    After running the toolkit, force shutdown your Surface.
    1. Press and hold the power button until the screen turns off (about 10 seconds), then release the power button.
    2. Press and release the power button to turn your Surface back on. You should see the Microsoft logo.
    If that doesn't work, use this shutdown process to make sure your Surface completely turns off.
    Press and hold down the power button until your Surface restarts and you see the Windows logo screen (this takes about 20 seconds), then release the power button.
    You may check this thread for updates from our Surface Team. Also, you can find some solutions that worked for other community members.
    If you have additional questions,  please let me know by replying to this thread. This way, I'll get notified and respond back to you as soon as I can.
    Regards.
    2018-07-20T15:29:57+00:00
    Also having the same reported problems here. Definitely seems correlated to the latest Windows 10 updates. I fixed this in the past by rolling back Geforce drivers but no luck.....
    Having the same weird charging thing too.
    2018-07-21T01:32:40+00:00
    Same problems here on my Surface Book 2. NVidia GPU keeps disappearing. Any update on how to fix this is much appreciated. Hard reset didn't help.  I am running windows 10, version 1803, build 17134.165
