2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-15T13:12:18+00:00
    I did the same back around that time. Never had an issue since.
    2018-07-15T20:53:12+00:00
    I have submitted the info to this issue to a law firm that handles consumer protection cases to review.  If your also interested in contacting the same law firm.  Please do so at this link:
    Krohn and Moss Consumer Law Center
    https://www.yourlemonlawrights.com/
    I look forward to seeing if getting a firm engaged will spark Microsoft to fix the issue quickly or end up loosing big time right in the public eye.
    Microsoft its time to step up and fix this issue or I can only assume that making law firms aware of this issue that specialize in specific cases like this will not end well for you.  Are you ready to fix it now?
    In the UK this is my latest reply from Microsoft
    "I did do a Google search and checked the sites that you mentioned on the first email it was cited.  Regardless of what we took from the search, it is not a recognized flaw and past the first 30 days, I cannot process a refund.  Beyond that the standard support options are available as previously discussed."
    I cannot understand when there are many of us experiencing this,  Greg the moderator has said to watch this space we are working on this fix yet the Customer Support Services are denying there is a problem - make up your minds Microsoft!  Its very very poor!
    2018-07-19T17:35:52+00:00
    I purchased my Surface Book 2 about 3 months ago and have been steadily using the device in both laptop and tablet mode, as well as consistently using programs that run the dGPU. However just a few days ago, the device stopped recognizing the dGPU after waking up from sleep. Whereas it would normally run the dGPU when a program that required it was started, it now runs the integrated graphics as it does not detect the presence of a dGPU.
    At first I could fix the problem by detaching and reattaching the screen, but that no longer works. How can I ensure the device detects and uses the dGPU after sleeping or being in tablet mode?
