2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-15T11:45:44+00:00
    The problem is 2 things.  One, I should not have to figure out how to get my GPU to function on a $3200 dollar laptop.  Two Microsoft actually advises not to install anything other than specific Microsoft created drivers for hardware.  For example that Nvidia driver is not purpose built for how the Surface Book operates.  So that could in theory cause more harm later.  I want my laptop to function as intended or I want to return it and buy the new Macbook Pro.  I am definetly going back to Apple.  Microsoft can kiss my....  They quite frankly dont give a damn.  Microsoft gives the worst support help on the planet.  Never again ever!  If they want my business ever again they better move mountains to make me happy at this point.  Never again!
    2018-07-15T12:03:20+00:00
    Yes, consumers in Illinois may use the federal Magnuson-Moss Warranty Act to provide them with relief for the purchase of any used car, truck, SUV or other consumer product. The federal Act supplements the protections of the Illinois Lemon Law to allow purchasers and lessees of any consumer product, whether new or used, to seek relief if the product turns out to be defective and cannot be repaired despite the consumer affording the manufacturer a reasonable opportunity to do so.
    We can all return the machine under the Magnuson-Moss Warranty Act if they cant fix it.  Which they have not offerred any permenant fix.  6 months is more than a resonable timeframe.  They have failed and every single owner can return it.  This is a federal act so it applies to all 50 states!  Happy returning!  I am going to get a Macbook Pro after I get my money back.
    2018-07-15T12:22:04+00:00
    I have submitted the info to this issue to a law firm that handles consumer protection cases to review.  If your also interested in contacting the same law firm.  Please do so at this link:
    Krohn and Moss Consumer Law Center
    https://www.yourlemonlawrights.com/
    I look forward to seeing if getting a firm engaged will spark Microsoft to fix the issue quickly or end up loosing big time right in the public eye.
    Microsoft its time to step up and fix this issue or I can only assume that making law firms aware of this issue that specialize in specific cases like this will not end well for you.  Are you ready to fix it now?
