2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-13T17:14:53+00:00
    I'm now having the same problem. I will be just using my Surface Book and the GPU will disconnect. I've also noticed the battery indicator will still say the device is charging/not charging after I have already unplugged/plugged in the power.  MS needs to fix this ASAP.
    2018-07-13T19:26:59+00:00
    On the plus side, I'm pretty sure the GPU is not being damaged.  I'm pretty sure it is just being "lost" in a fashion similar to if you detach the screen (software and/or hardware is doing something it clearly shouldn't and losing it).
    On the minus side, it is really annoying to try starting up your graphics-intensive application only to find you need to hard-reset your SB2 again.
    I don't think the lemon laws apply (but they do vary by state) as I believe it has to be a professional attempt to fix (and not just you doing a reset (which is a work-around and not a fix).
    Personally, I'm still glad I bought the SB2 as it works really well for me (except when the GPU gets "lost" until a hard-reset).
    2018-07-15T08:11:49+00:00
    I updated the Video card driver direct from Nvidia in May this has fixed the issue. I have had no loss of the card since.
