2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-12T19:05:26+00:00
    Seriously Microsoft? Not fixed yet? Makes me regret buying this thing...
    2018-07-13T15:27:12+00:00
    LEMON LAW APPPLY?
    It just happened again to me for the 3rd time after doing the "hard reset" holding down the power button and volume button till the special config screen pops up and then exit out to a reboot.  Its getting stupid.  I only knew because I went to boot up a graphics intensive application and then it notified me I did not have the minimum CPU frequency requirement.  I just get this feeling that the GPU will start to entirely fail over a period of time because I feel this issue is causing electrical damage to the GPU over a period of many failures.  Thats the biggest reason why I am getting upset because I think I will be paying for repairs right after the warranty period.  MICROSOFT!  LISTEN UP AND GET THIS RESOLVED FOR THE LOVE OF GOD!  WHAT IS WRONG WITH YOU MAN?
    God be with us all here on this issue because Microsoft wont lift a damn dollar to help.  We can pretty much just caulk it up that we have a lemon.  Because if the lemon law applies to electronics then after 3 times of trying to fix the same issue I should get a full refund.  I would rather go buy the new MacBook Pro that was just updated with 32GB of ram and a 9 series intel processor.  This computer was rushed out and now its just a limping piece of garbage thats going to brake.
    2018-07-13T16:15:42+00:00
    Greg, three months have already left, will we have an adequate answer from Microsoft support ?
    All this is very sad....
