2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-11T16:35:38+00:00
    Thank you for your feedback and the great information you’ve shared about the NVIDIA driver missing experience. We understand the concern, and are currently investigating a possible root cause and solution. Please continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
    Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
    Greg
    Please update where you are with this fix Greg.  Microsoft support are telling me there "is no recognized flaw with that model"  however your post acknowledges the flaws we are all experiencing!  Please advise as yet again being told different things from different departments of Microsoft!
    2018-07-11T20:44:36+00:00
    Amazing, I'm another person affected by this. I paid a lot of money for the very high end laptop which doesn't have a working GPU intermittently. I followed the instructions for the hard boot using the volume and power button and then exited from the UEFI menu and no luck, until I read the comment about ensuring the power lead isn't connected, I tried again without the power lead connected and it booted up and saw my GPU, it even offered an Nvidia driver update. I wonder if this will fix the issue? I hope this issue gets solved via software updates.
    2018-07-12T15:03:06+00:00
    I recently had this issue, having only just updated to the latest windows update (I keep it on manual download only for the surface book 2, for this exact reason).
    For me, the thing that finally worked was the surface diagnostics tool, which is here.
    Although other things I tried that might have made a difference included a hard restart (Power button and volume for 15 seconds till you get to the bios screen) and installing the latest driver (whilst the card was still being detected in device manager. I did this in device manager itself).
    And to anyone else having this, or a variation of this problem, I would strongly urge you to turn off automatic updating until windows get this under control, as this issue has posts stretching back for at least a year, almost every time they update.
