2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-20T02:56:32+00:00
    Just noticed this on my this evening after getting a new external monitor (HP Omen 35) and connecting it via the Surface Dock. I'm definitely going to keep an eye on it before heading down to my local MS store - especially as I've just put a plain protection film all over it
    2018-02-20T02:58:25+00:00
    Now that i think about it, none of my Nvidia problems started happening until i hooked it to a Surface Dock!  I havent hooked my new unit up to the dock and have not had a issue at all, throwing the Dock in trash!  I bet half the dock users dont even realize their Nvidia card isnt functioning!
    2018-02-20T21:29:05+00:00
    I have this issue too.  Seems to be correlated with a connection of a second monitor with USB-C but I'm not sure.  The driver shows if you do view hidden and it says the GTX1060 is "not connected to the computer"
    I'm not sure what the easiest way to get it to reconnect yet...but some combination of power offs and reboots and diagnostic tests will get it to show up again.
