2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-09T22:51:46+00:00
    Already three months as I did a hard restart, everything was fine but just again the video card began to disappear, made a hard restart and now videocard returned back. I'am a little shocked that Microsoft has not yet given any response about this issue to us, on this forum. Next time I will not buy Microsoft products, and I will not advise anyone.
    P.S. All this 3 month I have not install official Nvidia drivers, couse i think the problem is in them......
    2018-07-09T23:08:52+00:00
    I had never had a problem since November when I purchased mine. I thought that Nvidia drivers and other software not approved by Microsoft was a problem. However a few weeks ago I finally lost my GPU and had a tablet latch failure. So far a hard restart has fixed both.
    It would be nice if Microsoft was a little more forthcoming about these problems and what if anything they are doing to solve them.
    Right now it seems like recognizing these problems and finding solutions is the responsibility of the buyer.
    Bad enough that we have to use data mining software disguised as an operating system and browser but at least that's free. We paid a lot for the hardware, it should be better supported.
    2018-07-11T06:35:24+00:00
    Your procedure did not work for me.  What does seem to work is to detach the screen, let the system sort itself out, then reattach the screen.  The NVIDIA graphics appears and is available for use while the computer remains on but does disappear again after a few minutes.  After either a restart or a power cycle the NVIDIA graphics IS NOT available and I have to detach/attach the screen again to enable the card.  This was not an issue when I purchased in March 2018.  In early May I recall a Microsoft upgrade that caused issues with the power button and I started getting messages that there was a problem with detaching.  I didn't notice then whether-or-not the NVIDIA card was still available.  Just discovered that today.
