2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-09T03:58:00+00:00
    Try a hard restart. After months with no problems I got a latch failure and missing GPU at the same time. So far the hard restart seems to have fixed both.
    2018-07-09T17:44:34+00:00
    Count me in.
    Lisaelston if you start or anyone starts a class action lawsuit.  I am in.  I will signup in a heart beat.  They are liable for neglagance at this point.  They have had ample time to resolve this issue and they have not even tried to fix it.
    Hi
    So received this from the escalation team just now
    " I did some research and found that although some people have had issues with the video card in a similar fashion that you have, it is only a few scattered threads representing a small number of customers.  If there was a serious issue it would be in Microsoft’s best interests to recall the device as the support would be more expensive than ending the product line, if that wasn’t deemed to be a viable solution they would modify the warranty as with the Pro 4. "
    Obviously just you and me with the problem and not seen as a serious issue!
    2018-07-09T17:58:35+00:00
    Lol!!!
    Just this single thread has 34 pages so far. Of course it's not a real problem.
