2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-07-05T20:12:37+00:00
    Someone mentioned this problem may be occurring because the power supply that comes with the 15" SB2 isn't adequate. I bought a Surface Dock and have been using that for the last month. I no longer have the problem with the computer not detecting the Nvidia GPU while using the Surface Dock as my power supply.
    Hello NaushadVirji
    Thank you for your help.
    My SB2 is always powered with the surface dock since the begining.
    I have tried this solution on this thread and it seems to work (for the moment).
    https://answers.microsoft.com/en-us/surface/forum/surfbook2-surfupdate/gpu-not-detected-in-surface-book-2/774e1993-4bd4-4e5b-a0b6-0b3197fedb42
    jketola replied on
    I'm on the same build of Windows 10.
    The following "hard restart" procedure has worked for many (including myself) in this forum:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard restart by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    If this procedure doesn't work, try the second solution (by Philip_Aaron) marked as an answer above.
    Please let us know whether or not one of these procedures worked.
    Regards.
    2018-07-07T15:06:10+00:00
    Regards.
    Thank you
    Work fine with my SB2 :-)
    SB2/15"/16go/1T
    Windows 10 pro 1803
    Version 17134.137
    2018-07-07T21:43:02+00:00
    I have exactly the same Problem! Are there any solutions?!
