2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-26T21:37:26+00:00
    I have seen numerous cases of this problem online but no satisfactory answer or fix yet.
    Last night was the first time that I did not shut my SB2 15" down but instead just closed it and woke it up in the morning. This evening when I played a game I noticed it was running terribly and when I checked my Nividia control panel it said that no Nvidia card was detected. Sure enough the Nvidia GPU was not showing in the device manager. Some of the advice I saw online said to disconnect and reconnect the tablet screen. I did so and it appeared again but only for a short period of gameplay. After a couple of minutes the fan went crazy in the GPU. I closed the game. The card was still in device manager but when I checked again a few minutes later it had gone.
    How do I and the many other people experiencing this problem get my GPU to work right now and stay working? Or do I need to return this extremely expensive device?
    Thank you.
    2018-06-27T17:56:56+00:00
    Hello Sean,
    Thank you for letting us know about the issue with your Nvidia discrete GPU driver that works intermittently. We recommend that you force shutdown and restart your Surface Book 2 then check if the issue persists. If it does, we need to know the build version of Windows 10 installed on your device. You can check it out by clicking Start and on the search bar, type winver .
    After you have completed restarting the device, please check for updates in Settings > Update & Security > Windows Update to ensure you device has the latest drivers and fixes available.
    Kindly give us an update about the situation so that we can assist you further.
    Thank you.
    2018-06-27T20:45:25+00:00
    Surface Book 2 13" Nvidia Card, disappearing with Win Version 1803 (Build 17134.112).
    Any news on this? Where can i find the firmware (BIOS) version?
    I can't believe that i have spend so much money and now such an essential thing is not working and microsoft has no fix after 3 month. That drives my brain crazy. No wonder are all this young people switching to apple. Bad times, i am sad.
    I wrote Linus Tech Tips (www.linusmediagroup.com) please all here do the same we have to wake up this company!
