2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-26T16:40:29+00:00
    Guys, I know it's really frustrating but are you trying the hard restart mentioned several times in this thread?
    It takes a couple of minutes at most and fixes the problem for a time.
    I'm not remotely suggesting this lets MS off the hook!
    However, given the first time I did it, I didn't experience the problem again for a few months, I personally can handle one hard restart every few months.
    (NOTE: This is not a 'refresh' of any kind, it doesn't affect your files or reinstall Windows, it's just a hard/forced restart which for some reason fixes the problem.)
    2018-06-26T16:50:52+00:00
    see my suggestions below.
    I too am using the SB2 for drafting, rendering, animation etc. It was giving me **** but I held out & figured out a solution on my own. I had the Razer Blade but couldn't stand the glowing green snake, obnoxiously loud fan & janky build.
    Overall, the Surface Book has been a beast. Prob my favorite laptop once all the bugs are fixed.
    I just wish MS dev would care a bit more for a $3k machine.
    -try this Nvidia Hotfix (https://nvidia.custhelp.com/app/answers/detail/a\_id/4661/~/geforce-hotfix-driver-version-397.55)
    -update the OEM drivers from MS (https://www.microsoft.com/en-us/download/details.aspx?id=56261)
    2018-06-26T16:54:55+00:00
    Someone here needs to take to youtube to share complaints for “Reasons Not to Buy a Surface Book 2”.  The content has to be good enough to get views and shares, and that would have a lot more impact in getting attention from MS.
    To be honest, the SB2 is _almost_ the perfect computer.  It’s just shy of amazing.  It falls short in significant ways that ironically Microsoft could easily address if it was made a priority.
