2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-26T16:31:05+00:00
    My opinion is that Microsoft could care less.  They could just make a public statement and get a fix.  Unless its related to a hardware issue in power draw when connecting and disconnecting the tablet from the keyboard.  Which in that case a full recall would be so damaging to sales and consumer confidence.  Especially since they have now ignored it for over 9 months.  Business sales would slow to a hault and million dollar deals would fall apart.  So they have decided to  litigate the issue extremly quietly.  Honestly for such a big issue I am blown away by how poorly they have attempted to resolve the issue.  I can tell you just from watching the lack of response from Microsoft, says they have still not changed from when I left to buy a MacBook Pro.  I have decided this will be my last Microsoft computer period at this point.  Scociety deserves better and its possible to have better.
    To Microsoft: thanks for reminding me why I left your OS behind many years ago.  I wont be comming back again.  Thanks for the worst service from a Top Teir Tech company I have ever seen on your flagship product no less.  You should be ashamed and embarresed if you have any humility left.
    2018-06-26T16:37:22+00:00
    If you bought it a week ago you can return it. You can also try the hard restart if you want to try keeping it.
    2018-06-26T16:39:29+00:00
    Take it back, get a nice MSI or RAZER laptop... much more reliable options out there in my opinion.  I also was a idiot and bought a Surface Studio, the bluetooth disconnects constantly and the only fix is to tap the touch screen, another major issue with no fix.
