2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-26T15:28:42+00:00
    Hi All,
    For me, this worked for me:
    2018-06-26T15:30:35+00:00
    This is all a pain in the ass, Microsoft get off your asses and put a fix out for this!   Spent almost 4K on a laptop and have to sift through forums of half baked fixes that work part of the time!
    Kudos to all the users here, but this is just stupid ridiculous.
    2018-06-26T16:30:22+00:00
    Just Spent $3000 on this laptop exactly a week ago for school as I need a portable laptop used at home on a docking station 80% of the time and taken to school a couple days a week using portable aspect. I use it for heavy graphical digital art/animation at school and wanted a powerful but light portable laptop that had a good graphics card because any other laptop that's a third of the price as tge Surface with graphics card was too heavy.
    BUT!!!!! Now after taking the chance on Microsoft made computer product I'm totally regretting it. Why did I spend all that money on a light laptop/book to only get a 500$ equivalent laptops display. I immediately was effected by the Intel integrated graphics only problem as I started working on school work. I'm at AZ technology school for digital art I cant afford to wait for a fix
