2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-24T17:08:41+00:00
    These methods do not work anymore. Myself and a few others on reddit can confirm that the hard reset method simply doesn't work.
    It was fixed for me for awhile but after the most recent update it came back.
    OS 17134.112
    2018-06-24T17:31:22+00:00
    I'm on the same build with no problems.
    I searched reddit and found 14 day old posts saying the hard reset method worked for them.   Can you point me to a discussion where people are finding that it does not work?
    Did you unplug the SB2 before doing the hard reset?  Some have said this is a critical step.  Have you tried the procedure above from Philip_Aaron?
    What UEFI version are you running? (I'm just trying to see if something is different on your system.)
    What version of the Nvidia driver are you running?
    Update:  I found a reddit post (3 days ago) that suggests that the shorter hard restart method doesn't work if the dGPU disappears too quickly.  This problem was addressed by the solution from Philip_Aaron.  Any chance you are having a similar problem?
    2018-06-25T13:15:57+00:00
    Nicholasr325 & Jketola,
    The problem came back for me a second time about a month ago and "hard restart" method didn't work on first couple of tries. Somewhat by accident I let the power run down to 0% in the base and very near 0% on the screen battery. I charged both batteries back up to a reasonable amount 20-25% range and tried the hard restart again. (no power plugged in of course) It worked on the third try for me.
    I can't explain why, but it seemed that letting the base die completely helped me. You may give it a try and let us know if that helps with yours...
    P.S. - for reference I'm on the same OS build(17134.112) and just use the Windows Nvidia driver ver. - 23.21.13.8808
