2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-20T17:32:14+00:00
    The following "hard restart" procedure has worked for many (including myself) in this forum:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard restart by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    If this procedure doesn't work, try the second solution (by Philip_Aaron) marked as an answer above.
    2018-06-21T21:28:47+00:00
    Having the same issue with my Book 2 (i7) in addition to occasional challenge of getting the Book to fire up after shutdown. Please tell me there is a fix.
    2018-06-21T23:26:18+00:00
    The following "hard restart" procedure has fixed the dGPU detection problem for many (including myself) in this forum:
    Can you give us more info regarding the problems firing up the SB2 after shutdown?
    Please let us know if you tried the above solution and whether it worked.
    Regards,
