2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-18T16:09:10+00:00
    I had the same symptoms and used the following procedure to fix the problem:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard restart by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    If this procedure doesn't work, try the second solution (by Philip_Aaron) marked as an answer above.
    Please let us know whether one of these procedures worked (and which one).
    Regards.
    2018-06-18T21:38:47+00:00
    4 hours on Virtual assist/online chat then phone tonight and finally Microsoft have admitted this is a hardware failure and it needs to be exchanged!  6 months of grief for a £2.5k laptop that has not been able to be used for its purpose - Design - and yet have spoken to 4 different departments in USA and UK and still no-one takes over the problem of resolving the exchange let alone the promised compensation .  I would rather not have the machine it has been that much of a headache!
    2018-06-18T21:47:51+00:00
    Below I'm assuming your problem has to do with detecting the dGPU.
    Are you sure it is a hardware problem?  Others in this forum have reported that they had their system replaced several times only to have the same problem reappear after a while.
    If you haven't already returned your SB2, you might want to try (if you haven't already) the following:
