2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-01-21T23:36:16+00:00
    Right there with you, I noticed the same thing when I detach the screen which I never typically do, I'm going by the Microsoft store in the AM and they better swap this out, it's about 45 days old and 3400.00, ain't no way I'm sitting quiet about this!!
    2018-01-21T20:55:00+00:00
    I've been having this issue as well and it is driving me crazy. I first noticed it several days ago but that is the first time I needed the Nvidia GPU in a while so it may have been there for weeks. The last time I am sure the GPU was stable was mid December. Here's what I've figured out so far:
    1. It doesn't matter what graphics driver is installed. It happens with the default driver from Microsoft, new Nvidia drivers, and an old Nvidia driver that I had installed right after getting the laptop (worked fine for a month or so).
    2. You can usually get the dGPU to show up again (very briefly) by detaching and reattaching the screen. The system will lose it again in a few minutes but you usually have enough time to try updating drivers or whatever.
    3. I have not been able to find any sort of pattern as to when the laptop loses track of the dGPU after the detach/reattach trick. I am not even using the dGPU during that time - just doing basic tasks (Word, Edge browser, etc). I was leaving Device Manager open to see when the Nvidia GPU disappears and it's just random.
    4. Possibly related other issues with the laptop: whenever I leave the laptop alone for about 10 minutes it reboots. Never happens when I am using it. I have set the power settings to never sleep, never hibernate, never turn off network, and to use the black blank screen saver instead of turning off the screen. None of those changes helped.
    I have given up on this after wasting a whole weekend on driver updates, to no avail. Several thousands of dollars spent on this laptop, and the only GPU I can use is the underpowered Intel integrated one that is also found in laptops a fifth of the price. I plan to make one attempt at a fresh install of Windows but if that doesn't work then I think I'm going to have to call it quits on the SB2.
    2018-01-21T03:17:27+00:00
    I have the most powerful Surface Book 2, have never had an issue.  Occasionally i will play a game (Forza 7) which is pretty intensive on the GPU, rarely do i play it but sometimes i like to.  Tonight i went to play it and it was taking forever to load and looked a mess, mouse was locking up and when i went into Task Manager i noticed my GPU was at 100%.  I went to Nvidia's site thinking i could just re download the drivers but when i had it auto detect it said i didnt have any Nvidia hardware??
    When i go into device manager under display adapters it just shows the integrated Intel, not my Nvidia???  Its like it just disappeared.  Nothing has went wrong with this laptop, it has been working perfect.
    Any ideas?
    Moved from:      Surface / Surface Laptop / Display and screen
