Duo 2's Wi-Fi Options missing "Auto-connect" option, looks like Android 10, not Android 11
2022-05-16T01:36:47+00:00
Per multiple articles I see on the Internet, Android 11 added an "Auto-connect" option per Wi-Fi network, so each can be set to auto-connect, or not, on a per Wi-Fi network. This would be equivalent to Windows' "Connect automatically" option.
One example article for this is https://9to5google.com/2020/07/09/android-11-wi-fi-auto-connect.
Here's a screen shot example from that article:
But I don't see this on the Duo 2, nor the Disconnect option between Forget and Share. In effect, it looks like the Duo 2 is still using the Android 10 Wi-Fi settings. Is this true for everyone (meaning MS still needs to give us the Android 11 Settings)? If not, any suggestions how to get the Auto-connect option on Duo 2?
I need this so I can disable auto-connect for a few specific problem networks that I only need occasionally (don't want to have to remember and manually type a password every time I do need them), but I don't want to turn it off universally, because for most networks, I do want them to auto-connect when in range.
Colin
Surface | Surface Duo | Network
    2022-05-31T15:26:21+00:00
    You are correct.
    You can use feedback to request a change
    Settings/About/Give Feedback to Microsoft
