Word 2016 always open in Side to Side view, even after changing it to Vertical view.
2017-04-07T23:49:07+00:00
Recently, my Word 2016 had defaulted to scrolling between document pages side-to-side rather than vertically. I keep changing (under the View tab) the "page movement" to vertical, but each time I re-open Word, it defaults to side-to-side (see picture).
I don't understand why the sudden change, nor why Word won't "save" the last setting I have it on. Is there anyway to change the default to vertical and keep it that way?
Surface | Surface Studio | Display and screen
2017-11-28T14:33:08+00:00
I had the same problem. You just need to add the key.
Exit out of Word.
In Regedit, find 'HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Word'
Add the key 'Last View', then in there add a D-Word 'WordViewStateUsePageStackArrangement', leave the value as the default (zero).
Restart Word.
Worked for me.
60 additional answers
    2017-08-29T14:00:48+00:00
    Hi Kevin:
    I assume still no resolution on this issue?  Other posters are correct in that the 120% zoom template save, really doesn't save ;)
    Paul
  2. Stefan Blom 352.6K Reputation points MVP Volunteer Moderator
    2017-08-29T19:36:57+00:00
    If you want to save the zoom with a particular file, the solution is to make use of Jay Freedman's add-in. See https://jay-freedman.info/.
    2017-08-29T20:28:14+00:00
    Hi Paul:
    Nope! Word itself still is defaulting to horizontal viewing. Moreover, saving the zoom setting misses the point (and, therefore, isn't a real solution).
    I'm somewhat adjusted to this issue on my Surface Studio...by using my Surface Pro 4 which doesn't exhibit the same behavior. lol.
    Thanks for checking in,
    Kevin
    2017-08-29T21:08:32+00:00
    Hi Paul:
    Kevin
    OK, wow, that seems remarkably indifferent to the issue on the part of Microsoft...but perhaps they don't consider this "feature" as an issue...?
    Thanks again,
    Paul
