I have a very similar (if not the very same) issue with my MS Surface Pro 128GB and my MS Wedge Touch Mouse.
It works ok - no lags - as long as I don't connect a Bluetooth keyboard.
The laggy movement of the mouse pointer starts when I connect my BT keyboard (SpeedLink ATHERA SL-7438-BK http://www.speedlink.com/?p=2&cat=242&pid=27746).
The BT keyboard itself works properly in conjunction with the Wedge Touch Mouse.
I have tested both BT devices connected to a Lenovo ThinkPad running Win7x64: there is no lag in mouse pointer movements on the ThinkPad. So there is no general issue using these two BT input devices together but only when both connected to Surface Pro. There is also no issue when the Wedge Touch Mouse is connected to the Surface Pro and the BT keyboard is connected to the ThinkPad (of course at the same time within the same room). I just checked to exclude a general radio issue caused by the BT keyboard.
As opposed to others I haven't noticed those lags in conjunction with heavy WLAN traffic. My WiFi base station is an AVM Fritz!Box 7390 with both 2.4Ghz n+g+b and 5GHz n+a enabled. Since I'm additionally using two AVM FRITZ!WLAN Repeater 300E to relay the 2.4GHz band the Surface Pro is connected via 2.4GHz.
Any thoughts on this?
Thanks.
