Please correct me if I am wrong but this issue was already known with the Surface Pro 1 and MS used the same buggy Marvell chip with the Surface Pro 2 because they don't care about user feedback AND they don't use their
own products...
Also don't forget that in the case of the Surface the Soft- and the Hardware is from the same vendor = MS!
To the Workarounds:
- switching to 5GHz means extra costs and it's not possible within any (business) environment.
- using a USB Wifi (or Bluetooth Dongle) blocks the ONLY ONE available USB-Port of the Surface!
You are partly right. The issue was found at the Pro1. However, the cause wasnt. That came later. Would you stop production of a 100 million machines on a hunch? Thats what it was. A hunch.
It is still a business, and a partnership between Marvel and MS. There is no difference on this partnership, and the partnership between Apple and Marvel - and yes, that is also the same software and hardware vendor. That doesnt make any difference. This
is a Marvel issue, and the fix (if one is possible) have to come through them.
The workarounds.
- You are right. It does cost extra money, but it also gives you a lot more options besides this for the Surface. I am running 5ghz at home, and I get much higher internet speed, because there is no interference from neighbors or anything like that. So
there are a lot of bonuses to this.
- True, but you asked for options. The solution to this, HAS to come from Marvel. Thats the problem. It is their hardware, and their firmware. The 2 workarounds are the only 2 known to work. If you want a solution, talk to Marvel.
Talking to newspapers and so on, might help. I have no problem in that. It might actually get Marvel to find a solution. However, blaming this on MS, when it clearly is not an MS problem, will not lead to anything. Thats my point.
