Power Cover Not Charging 100% 0% 100% ???
2016-08-27T11:39:33+00:00
I've seen many post, but no answers?  Surface Pro Classic and just bought a Power Cover.  Power Cover is recognized as both a keyboard and a battery under devises.  All firmware ever pushed is there and updated. Battery #1 and Battery #2 show in the battery menu...but not charging or maybe 100% charged is completely depleted.
Once the internal battery reaches 80% (or so) the Power Cover charge goes from 0% to 100% and not charging.  Once the internal battery is depleted, the Surface shuts off and the Power Cover sits there happily doing nothing to help.
Has Microsoft just ignored the many people that this problem has occurred to, or is there not a fix.  I'm trying to hold out till the Surface Go, but this battery thing is annoying to deal with.
Please don't add the gif. of how the batteries charge or how the blue fills the keyboard and monitor, please please don't answer with that.
Surface | Surface Pro | USB-C
    2017-05-30T11:00:51+00:00
    Here are some hints for that repair job coming from a perspective of someone with less experience. I have never used a Multimeter before (I got one specifically for this and some cheap cables and tape to connect a battery) and worked with batteries only so far as to put them into things.
    Some things that nobody has mentioned about fixing this yourself is that the plastic covering the metal is really tough and annoying to deal with. (and it's best to get rid off all of it)
    Someone said to use a razor blade, which I did. I probably should have switched sooner to maybe a paper knife, which in hindsight might have been better, as the plastic and even the outer leather skin took me ages (it was a leisurely project, where I didn't really insist on using my brain much and being terribly efficient is my only excuse).
    I also used a 9V battery for adding (?) the voltage, and found that the first tenth of a volt go really quick and it really hits diminishing returns fast.
    I started at about 1.6 V on each battery.
    In order to get every battery up to about 2.7 V (2.3 V wasn't sufficient), I actually had to let it sit for an hour or for each battery (9V is probably not the best Voltage to use, but I only had 1.5V lying around, which is probably too low, if I had to do it again I'd try 5V).
    Also take care of not mixing up the connectors or you'll actually substract some Voltage (which I did, but that can be reversed).
    Another thing is that when you open the back and the connector is facing away from you and you look at the four batteries in front of you, that the first battery will always have the same Voltage as the third one, and the second one will always have the same voltage as the fourth one (maybe that is something super obvious for someone who knows things about electricity). So you only need two charge two of the outer ones and don't have to bother with the others.
    When putting the thing back together adding the metal plate back, screwing all the two dozens little screws back in is a waste of time, but 3-5 of them are bit shorter and wider than the others (it's subtle), it's probably best to mark their position and have them in.
    So I hope this encourages people to try this, if they find themselves out of warranty, like I did.
    I imported mine from the US to Germany and got a full refund and got to keep the thing, so I'm
    fairly happy, that I did the repair. Just having a needlessly thick, non-glowy type cover would have
    been lame.
    2017-06-29T03:53:40+00:00
    For those that have done the repair - and gotten it working...
    I am hoping that you can get me a data point.
    In another thread:
    https://www.reddit.com/r/Surface/comments/4zmrtm/surface\_pro\_2\_power\_cover\_jumps\_from\_0\_to\_100/
    I saw mention of a tool:  HWmonitor
    This appears to measure the voltage across the battery within the power cover keyboard.In his thread, it was 11.793v - and he was having issues getting his to charge.
    I picked up a used one, but am in the same boat as others.  Mine seems ot have a *much lower* (11.2v in the same tool)...
    But over the course of ~300 replugs of the keyboard, it has slowly climbed to 11.4v
    I can also see the voltage momentarily jump to 11.5v after I reseat it while it appears a charge (or handshake of sorts) happens.
    This seems to give credance to the folks that say "unplug and replug it a ton of times and it *might* charge".
    So far as my question:
    For one that is taking a charge - what is the "Current Voltage" that this tool measures for the Power Cover battery?
    Seems like I've got long ways to go to get this one working (unless I decide to open it)
    2017-07-02T19:27:36+00:00
    I posted my how-to on Reddit Here
    2017-07-02T21:35:18+00:00
    Not sure if I should be annoyed or not, no real credit given on the post and trying to work out where I was inaccurate!
    Pete
    2017-07-03T00:25:31+00:00
    Yes, you should be annoyed. The inaccuracies weren't necessarily referring to you. There's a lot of fragmented information in this thread spread over 8 pages of replies, so I combined the collective knowledge into one how-to.
    I do think a 1cm measurement from the ridgeline on the long side without the docking connector is more appropriate though.
    I added "Pete_521 is the best." to my Reddit post.
