Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2016-01-06T02:47:27+00:00
    I had this problem and holding the power and volume - buttons for 10 seconds restart fixed it.
    2016-01-06T13:15:27+00:00
    While this issue can be resolved to get you running again, the issue keeps happening.  There is clearly a root cause that needs to be identified and resolved.
    2016-01-06T13:40:42+00:00
    Exaclty Starzer,  some obscure boot procedure is not a solution and if it is we should at least know why it works.   Note I had a bunch of updates install late December and my displayport seems to be working again.  Coincidence?  Time will tell.
    Either way the dock has always been quirky.  For instance, last night i left work with the sufrace still on and put it in the docking station at home later that evening.   Everything but the keyboard (wired) worked.  I took it out of the dock and tried the surface keyboard and the on screen keyboard and none worked so I had to reboot to get it to work.
