Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2015-07-17T18:27:09+00:00
    I have had two docking stations for a Surface Pro 3 for external monitors, one at home one at the office now for several months. No problem all worked great. This morning one at house wouldn't detect the monitor, went to work, the dock station there would not detect external monitor either. I can plug either monitors directly into the Surface and they work fine. Why would both dock stations go out? I would think it is unlikely the dock stations are at fault.
    Have tried all the recommended fixits. Checked drivers - all working and up to date.
    OwenSOB
    2015-08-01T04:43:14+00:00
    I had exactly the same thing happen on July 28th. I have two docking stations with very different monitors and one suddenly stopped working while I was using HPAiO Remote. I plugged the Surface Pro 3 into my other Docking Station and it briefly flickered with part of a display then also stopped. Both now show No Signal. I have tried everything from trying to "Detect" the second monitor to "Windows Key" plus "P". It won't detect and it wont duplicate or extend. I tried a System Restore Point prior to July 28th, but that made no difference. All Updates are installed.
    2015-08-05T11:47:13+00:00
    After updating SP3 to Windows 10 I started to have this issue (WP8/8.1 - no issues). Monitor not switching on, if connected to Dock.
    Rebooting the device helps, until SP3 went to sleep or removed-placed back on the dock station.
    However, in the device manager monitor is detected, when the video cable is plugged. Re-plugging the cable does not solve the issue.
    mDP port on the SP3 itself works fine, but this is not convenient in the business environment and frequent plugs not really healthy to the port itself...
    Please advise.
    Cheers,
    Alex.
