Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2014-08-17T03:44:39+00:00
    FWIW, Accell is one of the better cable manufacturers. I have a Cables2Go miniDP 1.2 cable & it worked with my old SP2 & an Asus 4k monitor (PB287Q) but then again that was a POS monitor. Keep us updated.
    2014-08-17T21:46:51+00:00
    I'm also having problems with mDP on my SP3 dock.  I've been using my SP3 without a dock until yesterday, and decided to get it all set up today.  The same cable/monitor combination that's been working great with my SP3 doesn't work at all with the dock.  There is no detection at all - the computer simply does not see the monitor.  If it take the mDP cable and plug it back into my SP3 (docked or undocked), it works fine.  I've tried all the troubleshooting steps.
    2014-08-18T02:54:00+00:00
    I'm also having the similar issue and I went to the near by MS store and changed the docking station also but still same issue. Let me know if you have any fix for it. Tomorrow I'm planning to change the cable and see.
    Vinodh
