USB-C Power Output for Microsoft Surface Go 3
2023-06-12T08:11:30+00:00
Similar to this question, I'd like to know what sort of devices could be powered off of the USB-C port on the Surface Go 3. I.e. how much power can the tablet output to another device?
My company currently uses Surface Pros, but we'd be interested if the Go 3 would be sufficient for our purposes.
Slightly off-topic but is there a specification for the whole surface line what their USB-ports can handle in terms of output? It would be nice to get the whole picture of what we could use.
Surface | Surface Go | USB-C
    2023-12-15T00:32:17+00:00
    Hi RodelioP
    Is it that Surface Go 3 can only support 7.5W drawn from its USB-C port ?
    If Surface Go 3's USB-C port can only support power output of 7.5W, does it mean when a USB-C hub with mulitple USB-A connection to external USB devices is connected , according point 2, only one external USB-A device will work at any one time, would like to some elaboration on this. What does this mean. Thanks
