Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2017-06-06T10:03:00+00:00
    Hi All,
    I've lost track on this thread because the problem has been disappeared after these updates (or less become an issue). But after the updates I also did a factory reset to my SP4 i5 8GB. So not sure which one of those solved the screen problem.
    But suddenly the problem reoccurring about a week now, usually after 10-20 minutes of use and or after 5 minutes watching Youtube. My device is always up to date, the problem came after a couple of updates that follow the creator update. Well, from my experiences, the screen problem usually reappears after big windows update and I suspect any updates that causing high processor use.
    Today I, desperately, open Task Manager soon after startup and what a surprise to find out the processor is at 100% when I haven't open any application yet, until I realized that I have so many app that run on startup like OneDrive, Send to OneNote tool, SpotifyWebHelper, Windows Defender notification icon, Dropbox, Google Drive, Spotify, Slack, HP Printer Driver utility that cause high processor use.
    So, you can see the pattern. It is silly, but, maybe the processor is shocked/tired/getting hot after 100% use on the startup so can't perform well after that. :D
    So I tried to remove almost all startup programs especially the one with high impact and as typing this comment,  I already spent about 1-2 hours without screen flickering. I also watched about 12 minutes video on Youtube about half an hour ago. The problem is gone surprisingly.
    Will update this comment if the problem comes back!
    2017-06-06T10:13:25+00:00
    This happens for me in Surface UEFI mode so I don't think that hard reset may help. It is hardware failure or firmware bug. I'm afraid if it's hardware failure :S
    2017-06-06T11:30:26+00:00
    I went almost a year with no problem.  Now I get flickering whenever it's on more than an hour or so. I think it has to do with the screen heating up but I'm not sure.
    2017-06-09T02:43:26+00:00
    I‘ve got the exact same problem and I noticed some patterns.
    The time for jittering to occur seems to depend on how long the surface rests for, if I shutdown surface for one night and cold boot, it will takes around 1-2 hours to shows jittering, however if it rests for only 5 minutes or so it will only take minitutes to show the problem...
    I did try to contact support and sent my surface for replacement, but they said my surface had taken water damage (really can't recall when) and they couldn't do anything, all my warranty was lost! At the beginning I thought the problem is caused by water damage, but after searching on the internet I don't think so now...
