Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
  1. Deleted
    2020-12-04T04:51:18+00:00
    HiBryanH_[MSFT],
    I'm from Malaysia. May I have a reply from you? if I want to repair the surface pro 4 screen Flickering problem needs to pay how much? since I have bought surface pro4 for almost 5 years, but now I using an extension monitor. I unable to use my surface pro4 in a coffee shop.
    I have a similar issue too. Please help.
    2020-12-07T13:28:31+00:00
    Hey Everyone,
    Bryan [MSFT]
    Dear Bryan,
    I am facing the same issue here, and there is no support from your side at all.  my warranty ended on 06/20/2017.
    2020-12-08T09:03:24+00:00
    Finally a response from microsoft.
    but what a ridicolous response.
    This computer was purchased 19/12/2016. We have had problems all year. according to your email we dont qualify.
    i have another microsoft pro, and had problems from day one. Ordered direct. After miltiple calls and emails, we were told it would be replaced...was it...NO.
    I have a computer, not microsoft, that is over 8 years old, and still going strong. Microsoft is rubbish. I only purchased them due to school requirements, otherwise, forget it.
    To say there are only a few Pro having this issue..thats ridicolous...I’m sure there are many out there, people just can’t be bothered with these pathetic responses. I have x2 surface pros, both with problems.
    I will do everything in my power to not purchase microsoft ever again. I will slso ensure family and friends don’t either.
    Thanks for nothing.
    Lisa
