Yes, I ended up working with wholesale gadget parts (WGP.com)
Screen used to replace my pro4 version 1, SKU MI00067, 119.99, LCD Transfer flex cable sku MI00105, 7.99, tesla blacks double stick tape SKU-TL00477, 4.49
Now if during the screen removal you mangle your antennae as I did, use , 1 mil copper foil EMI shielding conductive adhesive tape you can buy on ebay for about 10.95. You must be sure these antennae are almost the same as what
was installed and be sure the copper wraps around under the antennae board so when screwed down the copper makes contact with the required points on the main frame.
When you remove the screen youll need to disconnect the cables from touch digitizer connector controller board, be careful because the clasp that holds the cable down and secure can be broken, new board costs about 12.00
Now these are the parts I used to redo my Pro 4, I messed up and broke some things that cost me extra but in the end I fixed my Pro 4 by myslef by watching videos and asking the tech guys at WGP. Before you buy any parts for your
Pro 4 talk to the tech guys at WGP (Brian is the main guy) to be sure you get the right stuff for your pro 4.
The reason I did my own repair is because I felt I had nothing for me to lose. If my repair didnt work I could send the screen back for a refund so I would be out of pocket very little. I didnt want to spend the money to have somebody
do this for me as the cost would exceed the benefit as you can buy a used pro 4 for under 500, some with new screens and some possibly with new pro 5 screens already installed as they are rebuilt for resale market. BTW WGP may do repairs I never asled so if
your interested ask them for a quote or repair referral.
Good luck, lots of misinformation online, I was told by several so called experts that a pro 5 screen wouldnt work unless I had the Version 2 pro 4 which I didnt. Kept asking around and found some who said Pro 5 screen would work
so gave it a try and it did. The one guy who turned me to on WGP and swappinjg the pro 4 screen with pro 5 I found on Ebay selling refurbished pro 4, he was good enough to share with me at no financial gain to himself.
