Surface Pro 4, Screen Flickering, Shaking
2017-01-19T07:47:47+00:00
Hi All,
Update: Flickergate is now having a forum to bring all affected users at a single platform to plan for resolvement of issue. Please join at
 https://forum.flickergate.com
UPDATE: Check FlickerGate.com for videos of the problem and to submit your own.
I purchased SP4 device a few months ago and it was working fine for a month. Then I noticed that when the CPU is at its max, the screen flickers a bit. Investigating further revealed that it flickers even if it is setting idle. It does not flicker if at least one of the following thing is done:
  1. A video being played in browser
  2. If I keep the touch screen busy by either taping it or keeping a finger on it
  3. If I use the touchpad
  4. If keyboard is used for typing
This resulted in making the device completely unusable while reading articles or ebooks. I am a developer, most of the time I have to read the code and to do that, I have to constantly keep a finger on the touch pad or the screen. I contacted surface support in October and November and was told that the developers are working on the patch. Looking at the updates the developers are pushing since then, I don't think anyone is even aware of the problem there.
My previous support ticket numbers are:
 ***deleted personally identifiable information***
Just wondering if anyone else had the same problem (and the fix) and if not, what's the procedure for the refund? I will rather go for a mac then sacrificing $2000+ for a dancing screen.
Kind Regards,
Abbas
2018-05-11T17:59:00+00:00
Hey Everyone,
Creating the best products and experiences for our customers is our top priority.
We have heard your feedback and after careful examination, have determined that a small percentage of Surface Pro 4 devices are exhibiting a screen flicker that cannot be addressed with a firmware or driver update.
To support customers affected by this issue, we will replace eligible Surface Pro 4 devices for up to three years from the date of purchase, free of charge. If you believe your device is experiencing this issue, please visit our Surface Pro 4 screen flicker article for more details.
Bryan [MSFT]
2,779 additional answers
    2020-08-29T01:18:59+00:00
    O ya and i want me a graphite replacement
    Surly. It had occurred to u in theory the constructer of the device would be best at servicing.why dont have to hear from outside sources better options then the head of the legion.
    I just got me this thing.. and i get to explain it on a phone.. that keyboard did me alot of good
    2020-09-02T10:01:20+00:00
    My daughter and sn have had major issues from day 1 of when purchasing a surface pro 4.
    Son's computer ordered online-screen wasn't working, replaced, then wasn't working well, replaced again. Keyboard wasn't connecting all the sudden, had to buy another one. Stylist wasn't working, needed to purchase another one.
    daughter- bought through ****---keyboard wasn't connecting, had to purchase another one. stylist was not connecting after 2 years, haven't bothered about replacing as has already spent enough, now screen has been shaking for last 6 months. Tried a number of things to try to fix it, as per-forums.
    Honestly, I have had enough...my previous computer last over 10 years...without any issues...new tech can go in the bin!!! It's all terrible.
    so tell me...how to actually fix a shaking screen????
    2020-09-28T15:30:26+00:00
    I had the same problem, im no techie but researched online found plenty of conflicting info, bottom line. I replaced my Surface pro 4 V 1 screen with a pro 5 screen, new cable and it works perfectly. Frist tried new pro 4 screen but had the same flicker ghosting problem, so tried pro 5 and it worked. Staff at wholesale gadget parts were great and provided what I needed at great price 126.00 for pro 5 screen and cable with doubled sided tape for install.
    During original pro 4 screen removal I demolished the screen and the three antennae located at the top center of the screen. several good video to watch to show how to remove the screen. But didn't know the antennae were ez to destroy with screen removal and the replacxement part is not available, so be warned.
    Had to rebuild the 3 antennae using copper conductive tape, not difficult to do but try to avoid .Use hair dryer on hot to soften tape under edge os csreen and then work loose starting on bottom ends of screen and work loose until all thats still connected is top of screen, use heat and slow easy moves to work loose so antennae and camera lense are not compromised.
    Take about 1 hr, glad I did it and now how my pro 4 working again.
    2020-09-28T15:46:17+00:00
    Can you provide more details on where you got this Pro 5 screen and cable from and where you had it repaired (ie country, state/province etc)? I'd love to fix mine but can't risk it being destroyed.
